sr20det bottom end
xero1
Car: 08 Altima Coupe
whats the difference between the s14 and s13 sr20det bottom end?
Slipstream
Car: '94 Sonoma, '90 300zx n/a
I think one difference are the pistons.
xero1
so a s13 redtop head should bolt up to a s14 sr20det block?
vutony
xero1 wrote:so a s13 redtop head should bolt up to a s14 sr20det block?
nope...totally two different engines.....only s13 redtop and blacktops are interchangable
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
S14 SR has the VVT Head or whatever it is.
180fan
Car: 89 fastback
they are slightly different. the front cover for the s14/15 is slightly different and there is another line for oil running through the front on the s14/15. Otherwise the crank, and pistons, rods are all the same.
Head wise, the heads are different. low port on the s13 and high port on the s14/15.
Yes you can put a s13 head on a s14/15 block.
xero1
do i have to stop up the oil passage on the s14 block if i'm going to use a s13 head?
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
my question:
why the "hybridness"
180fan
Car: 89 fastback
you don't have to plug up the oil passage. it will get covered with a s13 headgasket and head.
xero1
since the head gasket and head blocks the extra oil passage, will my s14 bottom end and s13 head setup be as reliable as a regular sr20det?
180fan
Car: 89 fastback
yes
xero1
Has anyone try this combination before?
