skyline084 »
https://forums.nicoclub.com/skyline084-u171542.html
Wed Nov 17, 2010 7:50 pm
boost leaks can be hard to find so just spray carb cleaner or something similar, than watch for bubbles.
ECU is real simple to check for codes..
Pull your ecu out, now look at the side the light is on.
There will be a hole with a tiny screw.(Philips head)
You probably have to pull a sticker off to get to it.
Now to read the codes, turn ignition ON
Next, turn screw CLOCKWISE and WAIT a few seconds, than return it back to its original position (ANTI clockwise)
When you return it back to it's original position, it will blink a certain number of times.
1st set of blinks=1st number, 2nd second of blinks equals 2nd number
(1st set of blinks are fast and the 2nd set are slow)
If i'm confusing you i'm sorry haha but watch it a few times.. the codes won't clear until you turn the key off)
Go to the nissan online mechanical section of these forums, click on the sticky link labeled TUTORIALS, and click on the link that says Codes: retrieving and reading.
It gives you a list of all the codes
(It shows you how to read the codes there too, but once again, they over complicate it)
