SR20DET bogges down under load?
ward28465
Car: 95 240sx blacktop SR
I have a 95 240sx with a blacktop SR, it was running fine and one night it just started bogging down when ever it was under a load. iam thinking its a MAF problem. has anyone ever had this problem or know what it could be? thanks.
180fan
Car: 89 fastback
does it happen in a particular rpm range? is the rpm limited anywhere? is it throughout the entire rpm range? you check for boost leaks?
nissanfreak8
Car: 1989 240sx, 84 Olds Delta 88 R.B.LS, 1995 Chevy Lumina LS
Well if u don't have any boost leaks then i would think that it is the MAF.
rotorimp
Car: 02 Xterra, 60 IH Metro
Definitely sounds like a boost leak
sean58888
Car: 91 240sx coupe
ah i had boost problem too before but nothing seem leaking so ive changed this sensor then it starts to boost again!! http://cgi.ebay.com/ebaymotors...06340
