240probs wrote:Ok right now the wastegate vac hose is on a t with the bov going to the throttle body i ordered one of those quick nipple things to put in my coupler on the hot pipe to seperate the bov and wastegate the guy that did this swap was kinda half a** so set my wastegate lower i take it i twist the peice away from the vac nipple on the waste gate so it opens sooner? Or tword? Basically do i make the bracket longer or shorter to lower boost levels and im at 15psi now how many turns till i get 7-9 psi?
You're mistaking an adjustable wastegate actuator for a boost controller. Can you take a picture of your setup?
To adjust the actuator rod properly, the rod should be just long enough to keep the wastegate door closed. Too long and it'll keep the door open. Too tight and you'll raise the target boost and crack pressure. Remove the C-clip and set the rod so that it slides right over door lever. Shorten the rod so it's just 2-3mm too short. That should be just enough.
Chances are that you have an aftermarket wastegate actuator, likely with a 12-14psi spring. Does it look something like this?:
http://www.atpturbo.com/mm5/merchant.mv ... _Code=VSR2
