SR20DET BlueBird 5sp AWD transmission Pics
zero1dhd
Car: 1995 Nissan Sentra
Does any one have good pics of this transmission or can u direct me to a website that does? I have looked for some, but I can't find any.
I would like to see the probability of converting my 95 sentra to this AWD platform
Ken Park
Car: 1991 240SX
The probabablity of you successfully converting any US Sentra to AWD is approaching impossible. It has been tried, unsuccessfully, and has not been tried since. I used to read about this on the SR20forum when someone would make a thread about it. Go there and search the topic. You should understand that the main reason it will not work is because of the rear suspension and the gas tank, not to mention that there is probably no room for the transfer case and no way for the drive shaft to route. You also have to realize that the AWD SR cars have no crossmember, you do and you need it. Just get a 00-01 B15 Sentra 2.0 SE or P11 G20 trans with the VLSD and do what you need to do to get it to work with your B14. They are much stronger than the 91-99 SR20 trannies and will work with very little modification.
zero1dhd
If you do not have anything to contribute to making this work - please don't tell me how it's not gonna work. I understand there will be a lot of work involved; however nothing is impossible.
Has anyone heard of a welder. You can cut and weld anything you want - including crossmembers, framing, body panels, etc. Yes cutting a frame or crossmember isn't a good idea, but if you have the car properly supported before you cut it and you weld in new framing that will give you the outcome that you want - you can do anything you want.
I am not guessing on this guys - I have done major frame work before including cutting and notching for clearance. And in fact if you know what ur doing you can make stock parts stronger than stock with the clearance you need.
So - In conclusion - if anyone has good pictures or contributing information you can give me - please send it too me; however I understand that the majority of ppl can't wrap thier head around this, so please don't tell me the "impossibility" of this, or how hard it's gonna be, cause I already have heard it and I know.
I have some rough drawings on the actual scope of work; however I need some more good pics so I can make some more detailed drawings. I will completely build this on the computer before I ever touch the car. this way I have a good idea of what is gonna give me the biggest problems.
So please send me some pics and also if anyone knows - Is the gear ratio in the diff of the 240sx the same as the gear ratio in the awd transmission??
nametakennow
Car: '06 MINI Cooper S
No one has any pics because no one has done it. If you're looking for a pic of the transmission itself, here you go:
I've seen a few others, but I can't find them.
zero1dhd
nametakennow wrote:No one has any pics because no one has done it. If you're looking for a pic of the transmission itself, here you go:
Yes this is exactly what I am looking for. Thank You very much. If you can find other pictures please send um this way. All the ones I find are of the front or top of the motor. I need the back and the side detail of the transmission (striaght on pics are the best) so I can roughly figure out where the rear output is gonna sit - I'm thinking I might need to put a c-notch in the crossmember - sounds like fun!!!!Again - thank you very much for your help!
Oh here is my rough drawing of the scope of work - please let me know if you see any major problems
http://wdwebco.com/reaper/project%20BBawd.htm
mrkanda
Car: 1989 Nissan Maxima GXE
Hello, Great Topic! How far have you gotten in the planning stages? I am very interested, cuase I want to do the same thing with my '89 Maxima (I want a 4-door Skyline R34, but since I can't get one here I'll just build my own). So, maybe we can work together on this.
-MrkandaGainesville, FL
nametakennow
Max to R34 is going to be even more ridiculously expensive and difficult. You might be better off importing a 4 door R33, since those are still legal.
modified GTI-r
Car: 2001 nissan almera n16
hey dear pp, am in need of some HELP or some info hear in ARUBA am making a project with my nissan almera n16, i are reddy did the inge swap to the sr20gtir but now am stok because i relly dont know wot els to do, i know i will need the come plet rear end suspension form the pulsra gtir but till dear, i can help my self now am confused so am in need some real HELP can some one help me pls????? pls let me know hear is my Email [email protected] thanks
modified GTI-r
[quote="modified GTI-r"]hey dear pp, am in need of some HELP or some info hear in ARUBA am making a project with my nissan almera n16, i are reddy did the inge swap to the sr20gtir but now am stok because i relly dont know wot els to do, i know i will need the come plet rear end suspension form the pulsra gtir but till dear, i can help my self now am confused so am in need some real HELP can some one help me pls????? pls let me know hear is my Email [email protected] thanks
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You realize this thread is 4 YRS OLD...
Untamed_Addiction
Car: awd 1993 nissan sentra b13
you can get the awd parts fron jdm_planet thats where im getting parts from im gonna do a rwd b13 drifter i got complete rear sub frame from him his name is chris he is my teams sponsor but he will get you the parts you need for the awd swap i was gonna do the awd swap but decided to go rwd its cheaper for me i have ka24de swap ling around in house but i garanty he has the parts you will need plus he sells them cheap and provides free shipping also we are gonna provide a tutorial on the awd/rwd conversion starting whit the rear sub frame install continuing to the swap
this is the link of his web site were the tutorial will be posted
http://WWW.OSAKAJDMAUTO.COM
or his ebay account
http://myworld.ebay.com/jdm_planet?ssPa ... TM:US:1181
you can follow my thread were ill be posting updates on the convesion
osaka-jdm-moters-sponsors-awd-1993-niss ... 06333.html
SR20?
Car: 92 Sentra SE-R - Turbo'd
92 Sentra SE-R - JDM swapped daily
check out www.sr20forum.com and www.sr20-forum.com
search "awd nx2000". I also saw a red b13 sentra that was awd on the forum but I wouldn't know how to find it again. But the nx was very popular cause it was a uber sleeper.
