mmashburn »
https://forums.nicoclub.com/mmashburn-u27397.html
Thu Aug 11, 2005 2:39 pm
I think I recall reading something about doing a compression test while leaving the radiator cap off..... if the antifreeze bubbles while your doing the compression test, then it's probly the head gasket..
cant you also change the oil and visually see if coolant has leaked in?
