sr20det blowing white smoke
s13_drftone
Car: S13 with sr20det swap
what could this be??????? car is blowing white smoke i was thinking that its my piston ring
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
white smoke is a coolant leak, check your compression maybe it is ur head gasket.
fregisr
Car: 240sx 1990
s13_drftone wrote:what could this be??????? car is blowing white smoke i was thinking that its my piston ring
when the engine is first started, does it smoke right away or it starts smoking after it has warmed up a little bit?
s13_drftone
when it starts! it smoke?????
gore
Car: 93 240SX hatch (ca18det)
since there is already a thread for this, mine smokes too. It doesn't smoke on start up, it only starts after its warm and only when I'm sitting at a stop for like over a minute. I'm thinking its maybe a bad turbo? I'm goign to check my coolant and oil levels tomorrow see whats going on.
fregisr
Car: 240sx 1990
s13_drftone wrote:when it starts! it smoke?????
it sounds like it's in your piston rings. Are you losing coolant at all?
gore wrote:since there is already a thread for this, mine smokes too. It doesn't smoke on start up, it only starts after its warm and only when I'm sitting at a stop for like over a minute. I'm thinking its maybe a bad turbo? I'm goign to check my coolant and oil levels tomorrow see whats going on.
If your's doesn't smoke until coolant temp has rised up, it's most likely your turbo. I unbolted my exhaust manifold and left a little crack between the cylinder head and the manifold for exhaust to come out to see if the smoke was before or after the turbo. If you don't see any smoke coming out of the crack then it's definately the turbo.
gore
I'm hoping its just the turbo. good tip thanks.
s13_drftone
im not losing coolant or anything!!! but i was thinking it might be piston ring? any suggestion
karmakaze
Car: 98 240sx SE
s13_drftone wrote:im not losing coolant or anything!!! but i was thinking it might be piston ring? any suggestion
unless your car is made of ****ing magic, if its blowing white smoke your loosing coolant. did you check to see if there is water in your oil or oil in your water?
my vote is either head gasket or damaged water jacket in the turbo.
ILikeMy240sx
Car: SR Power
I remember a while back.... before my 1st rebuild my exhaust cam was off by a tooth and it smoked like hell just like I had a blown headgasket
spider_slayer
Car: S14 240SX
S13 240SX
i'll go with damaged water jacket.......i remember a while back though drifter4life's car was doing the white smoke thing and it stopped when he replaced his thermostat.
JeremyVR6
spider_slayer wrote:i'll go with damaged water jacket.......i remember a while back though drifter4life's car was doing the white smoke thing and it stopped when he replaced his thermostat.
this is kinda unrelated, but my car blew smoke heavily at idle, but at WOT it was fine, turns out the ECU was fried and #2 injector was dumping to much fuel... causing it to smoke hardcore.
spider_slayer
Car: S14 240SX
S13 240SX
the injector dumping to much fuel would cause heavy black smoke. he indicated that his car was blowing white smoke.
vi3tkool
Car: 240sx fastback
I would check the intake. Sometimes oil come accross from valve cover
karmakaze
Car: 98 240sx SE
vi3tkool wrote:I would check the intake. Sometimes oil come accross from valve cover
but his smoke is white. not blue.
and thats the pcv system. and if its blowing that much oil into your intake your going to have a ****load of other problems.
Sr20_44
Car: Nissan 240sx Sr20det
New to the forum and don't know how to make new thread haha.
But I'm having the same problem. I just did a compression test (cold) and got low numbers. 85-110.
The car runs/drives and makes no noises. I was thinking its a turbo at first. Any suggestions?!
