sr20det blacktop boost and fuel problem
jjsz32racing
Car: 95 nissan 240sx
i have a s14blacktop with fmic,apexi S-AFC,intake,exhaust,430cc inj and im running very rich i can go about a qtr pedal and its fine i try and floor it and it jerks hesitates and then might open up a little. Boost leak or what do you think with those mods does anyone have similair s-afc and tell what you do to tune or tell the setup on it so i can put it in And i have a 91 z32 non turbo will that .mafs. work will it help performance
Modified by jjsz32racing at 3:23 PM 9/26/2007
Modified by jjsz32racing at 3:31 PM 9/26/2007
jjsz32racing
help
SpeedRacer1
Car: 1990 240SX, G35
Did you even setup the SAFC before you started the car? You need to set the SAFC up before you start the car.
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
your running 430cc injectors and the computer thinks you ahve the stock 320's. You'll be lucky to have a 8:1 a/f and im sure your coking the hell out of the exhaust and washing the cylinder walls with all that fuel. Maybe your AFC was set right but lost its memory, but regardless....TUNE THE SAFC and save your piston rings/lands.
