khilgers »
https://forums.nicoclub.com/khilgers-u8136.html
Sun Feb 15, 2004 6:49 pm
taken from srwap.com
S13 SR20DET:The stock turbo will be safe to 13-15 psi._ After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage.__ The engine should produce 230-250 RWHP at safe boost.
S14 SR20DET:The stock turbo will be safe to 13-15 psi._ After that, the turbo is past its efficiency range, and power increases will fall off and are not worth the risk of turbo damage.__ The engine should produce 250-260 RWHP at safe boost.
