pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sun Aug 19, 2007 12:58 pm
HI all,
I have couple questions regarding and S13 blacktop engine.
I got one and I installed it in a 1990 single came 240sx. I managed to wire every thing up according to heavy throttle. However, The ecu I am using is labelled as "E5". Cylinder # 2,4 have no spark, I have ohmed out the ignitor and it measured good.
1) My question is, I heard that I can use an s13 red top ecu on a black top harness, do I need to repin or modify any wiring or it is just plug and play.
2)When wiring a black top harness, is there any difference compared to wiring a red top harness?
3) On the blacktop harness beside the battery I got 2 red wires, one thin and the other one is thick, I can only see the thick red one on the Ka harness, where do you hook up the red thin wire?
I think the ecu I got is either the wrong ecu or defective as the pin for coil # 3 (spark for cylinder # 3) on the ecu side has constant 12Vs when ignition is open which it should not, and it should behave the same way as cylinder #1,2,4.
4) Any one knows where I can download an SR20det FSM, I got the one for an S13 with the ca18det but the ecu wiring is completely different.
Thank you,
Rafi
