Sr20DET Auto to Manual swap..
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Ok so I bought an Automatic SR20DET and a Manual SR20DET transmission/Flywheel/Bolts/Clutch.
Is it as simple as the KA where I just swap the trannys and everything is great? or is there some special Ecu mod I need to do??
I searched everywhere but I did not get any info..
Badfish
Car: 93 Nissan 240SX w/ black top SR20
Hey, Kenrik. Read the damn stickys at the top of the forum.
ALL OF THEM.
zerothread/145184
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Badfish wrote:Hey, Kenrik. Read the damn stickys at the top of the forum.
ALL OF THEM.
zerothread/145184
No dummy.. My car is already a Manual...
I'm converting the SR from Automatic to Manual... So I was wondering if there was anything special that needed to be done...
ser2102
Car: 91 dead. 90 getting did
when i got my motor, whoever had it before me did the swap, so i didnt have to do much to it. however, i think you need the wiring harness for the transmission probably from your manual car. and ive heard the auto ecu has trouble with idle when you convert it. on a manual, the idle is supposed to compensate for changes such as the brakes being used, and the PS pump. also the throttle position sensor is different. it doesnt have to be changed but i heard it helps.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
ok that's it.. the idle will be a little screwy untill I swap to a Manual ECU?
slydin'240
Car: 1993 240sx Coupe, 2003 Maxima SE
After what you have gone through with your motor set I think they should send you a free ecu.
