supreamS14 wrote:Hey, could you inform me how a compressor map works? Or link me to a page that explains it. Thanks!
this excel doc is a must to havehttp://
www.rs-enthalpy.com/tun...h.xlsit tells you how much air your motor is flowing based on its size. its preset for the sr20det.
use that for the X axis. which is air flow.
the Y axis. is psi translated into pressure ratiopressure ratio also factors in your ambient air pressure ( for cars in hot/cold weather or at low/high altitudes) .
pressure ratio = Compressor Psi + Atmospheric Psi / Atmospheric psi 1 is atmospheric pressure, an NA motor.
1.5 is roughly 7 psi2.0 is roughly 14 psi3.0 is roughly 28 psi4.0 is roughly 42 psi
turbo by garret explains it in detail, but its hard to understand without some help.
http://www.turbobygarrett.com/....html
some turbos give the max flow rate in lbs/min others do it in kg/s - the conversion isnt hard.
