180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Jul 28, 2004 11:36 am
I dont think the nismo thermo's a good idea. mainly because it'll keep your motor too cold for daily driving and it'll jack your mileage.
Downpipe fits from turbo extension (little elbow thing that hangs off the back of the turbo) and connects it to the cat. You'll need this, most clips let alone motor sets do not come with this part.
walbro's are decent and cheap. can't mess with the bang for the buck.
You don't have to get nismo injectors. to run 12 psi, you'd be edging near maxing out your injectors. If you plan on running 12 psi daily, get the bigger injectors.
the adjustable one is fine. The HKS one is a pretty good buy. bout 100 bucks gets you something that's pretty adjustable granted you've a vac pressure gauge and or a vac pump or something to measure how much boost you're running.
The ACT springless 6 puck, if you're gonna get a more streetable clutch, get the one with the sprung hub. You can try Nismo's copper clutch, but those are way expensive. I would get the 6 puck ACT with the sprung hub or look at some more of the exedy lineup. Unless you've got alot more money to spend in which case you can look into the multi-plate clutches like ORC, OS Giken, HKS, Blitz, Nismo, or even Cusco.
