SR20DET A/C question...
steeda763
Car: '91 S13 SR-Coupe, '96 BMW M3, '95 525iT
I have an S13 redtop with an OEM intake hose which barely clears the air conditioning pipe going to the A/C compressor. I'm positive that the connector is actually pushing in on the intake pipe a little bit, and it's not even converted to R134a yet.
Taking off or moving the intake hose is kind of a no-brainer, but then that would take the MAFS out of the system while the car is running and charging.
Is there something that I'm missing? I'm pretty sure that the evacuation connector (in front of the condensor) is smaller in size than the standard R12 or R134a connector, but is it safe to charge the system with freon from there? ...Or any other ideas?
Thanks
steeda763
Bump...anybody?
ILikeMy240sx
Car: SR Power
your car will run even without MAF. It will idle like crap and when you blip the throttle, it will run like crap but it WILL run for your AC.
Turning on the AC might drop the dile casuing problems but its worth a try. Just watch your fingers by the compressor blades ;-)
