180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Feb 25, 2005 3:21 pm
The lash has nothing to do with VTC. VTC has the solenoid up front that will move the cam around. If you get the cams built for VTC, it will bit slightly different from the Non-VTC cams. There is a difference in duration of a few degrees if my memory serves me right. If you want to keep your VTC, look for a S14/S15 specific cam. However, I think most of those cams will have VTC dumped if your head is built up that far to require such cams.
The lash killer kit is a remove and install, and alot of checking process. Remove the hydraulic lash adjusters and install the solid ones. Cram back in the cams and start measuring your clearances on the non-bumped part of the cam to the rocker arm with a feeler gauge. This takes a while so if you're an impatient lil' bastard, forget about it. If you're scared about it, get your machinist to check the clearances. However, do check the instructions that come with the different kits. They may differ with the specs they need.
