SR20DET 5speed trans noise
qwikxr
Car: '90 S13c - SR20det, '02 WRX Stg2 Enginuity OS EMS
Im thinking it's mainshaft bearings, but not positive..
When cold, it seems loudest, but as it warms up, it get quieter, but never really goes away.. It's a sortof whine, that goes away when the clutch is depressed, but returns when clutch pedal is released.. Most noticable stationary, but Im sure it's doing it moving, as well.. Car's too loud to tell
adrianfromthecastle
Car: 1992 Nissan 240sx
possible throw-out bearing?
qwikxr
Dont think so.. my past experience is that the t/o bearing makes noise when under load; when the pedal is depressed..
This is doing the opposite.. makes noise when released, or no load on the t/o bearing..
qwikxr
Is it true that a KA24DE trans will work, if i swap with the sr20det's bell housings?
johngass
Car: 92 240SX
yes
qwikxr
sweet.. I take it the ka24e trans is different, though?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The noise in the transmission is most likely the input shaft bearing.
The KA24E and the KA24DE 5-speed trannies are the same with the exception of some additional sensors which in your case is a non issue.
qwikxr
thanks for the info! As for the input shaft bearing, is this something that is readily available and fairly easy to replace? The wier part about the whining, is that it seems to disappear once i reach 4th gear.. I was listening to it a few minutes ago, while driving through town (30mph), and switching between 3rd and 4th , it comes/goes, depending on which gear..
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
To replace the input shaft bearing, the transmission needs to be disassembled. The bearing can be gotten from your friendly Nissan dealer.
Since the noise seems to change depending what gear you're in, other transmission bearings may also be worn.
Maybe you should just get another transmission; might be cheaper that way.
qwikxr
Thanks (again)
As far as clutches... Do I get a clutch for the K or SR trans? or are they basically the same? No, I don't know! :P
180fan
Car: 89 fastback
sr flywheel and clutch for the sr engine.
