IDriveFords »
https://forums.nicoclub.com/idrivefords-u50137.html
Tue Apr 29, 2008 10:24 am
If your gonna do all that your gonna wanna upgrade your headgasket and get ARP headstuds. I'm getting ready to do a similar setup and I think I'm gonna go with the same BC head parts and an HKS headgasket. Also you gotta think about a tune... I was gonna go with enthalpy. From what I read, with the turbo your looking at, you should be able to put down 300-350 with a good tune at about 16-18psi. Other people are probably gonna tell you about all the stuff you "might as well upgrade" while your at it but try not to listen to them or your pricetag will skyrocket. However, the headgasket and head studs are the essentials. As far as what cams to use I would read through the camshaft megathread if i were you, its very helpful.
