sr20det 2 wiring help
climaxsr20
Car: 1998 Silvia RedTop
hi i need help with the sr20det wiring. one is for the wiper. i have an s14 (98) with a red top sr20det does anyone have or know the wiring for this? also when i tap in the engine temp from gauge cluster to ecu the engine turns over but wont start. but when i start the engine and tap the wire into the ecu then it works. anyone know this problem or have a clue whats up? thanks.
virus77
Car: 95 S14, 71 240z, 97 e320
Read these two links carefully and you should be good. Sorry for the link to FA but its good info.
http://forums.freshalloy.com/u...94922
and
http://myweb.cableone.net/tain....html
Wiring Specialties
Vendor
The wiper wiring should not be changed when doing the wiring. You should remove the whole interface plug (the white one, next to the ECU) and splice it into the S13 SR harness.
Let me know if you need some help figuring this out.
DriftBandit
Car: this is my 3rd 240sx
I just wired my own harness for the wipers using the FSM and everything works perfectly, I can send you the pages I used if you want me too.
