sr20det 1/4 mile times
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
what can i expect form a stock s14 with a sr20det swap in the 1/4 mile?
lessthanjakejohn
Im pretty sure budweiser has a 14.1 on his s13 and his SR has stock boost and an FMIC. I think youd see the same on a S14
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
be more specific...redtop vs. blacktop i would assume be slightly diff. unless u just want a really rough estimate...
-Dan
MainEvent212
ok FINE!
s14 blacktop at max safe boost on stock turbo. basic bolt ons that i'd buy from dauntless. 225/45/17 tires on 17 lb rims...shortshifter
Infamous
there is no HP difference in the redtop and blacktop
MainEvent212
the s14 blacktop DOES have more hp than a s13 redtop or blacktop
that is due to a better turbo ( i think) and variable valve timing
Cyberkreig
Car: 1993 Nissan 240SX SR
Infamous was probably refering to 240sx2nr95's post where he says "redtop vs blacktop" I read that as "s13 redtop vs s13 blacktop". tho thats probably not what he ment..
nismodave
BIG FRIGGEN RED BUTTON>>>>>>>>SEARCH:angryfire
sxse
Car: no more 240, '04 YZF-R6
Don't Red tops have more power possibilities in the long run because they have a high port head? Like the blacktop is only better if you are going to max out the stock turbo...
just a tid-bit :)
Dano
Cyberkreig wrote:Infamous was probably refering to 240sx2nr95's post where he says "redtop vs blacktop" I read that as "s13 redtop vs s13 blacktop". tho thats probably not what he ment..
sorry, ure right, i didnt, i meant theres a difference between s13 redtop vs. say a s14 blacktop.....--->sleep deprivation at its finest!:pface
-Dan
Cyberkreig
sxse wrote:Don't Red tops have more power possibilities in the long run because they have a high port head? Like the blacktop is only better if you are going to max out the stock turbo...
just a tid-bit :)
The S14 blacktops, not the S13.
I H8 UR DSM
AN S14 IS AN S14...NOT AN S14 BLACKTOP.
i think there needs to be a clear understanding of that...
S13 Redtop sr20detS13 Blacktop sr20detS14 sr20dets15 sr20det
there was never a s14 redtop or s15 redtop, therefor the 'blacktop' designation is NOT needed when describing those motors, it will only lead to confusion...
Please please please people, start understanding that : )
dont confuse them by calling them blacktops...there is no s14
Jessehttp://www.rollhard.com
SR Sil80
Car: Cars, computers. gaming, web design, etc
mainevent212 wrote:the s14 blacktop DOES have more hp than a s13 redtop or blacktop
I didn't think it had the variable valve timing I thought that was just in the S15s. And I also thought (could be wrong) that only the S15s had a bigger turbo. I know the 14s have like 20 more horsepower than the 13 series though. I'd guess completely stock it would run like 13.9 or so if the 13s are running 14.1 stock.
I've seen a 13 run 14.2 stock w/ side mount and all, and I've seen an 18psi s13 run 13.2 (he was blowing his turbo because he didn't care cause he just ordered a new kit hah). So yea I'd say a stock 14 runs high 13s or low 14s depending on a variance of factors.
red240ne
Car: mmm...donuts
expect mid to low 7's, and you'll keep up with the pro stock's
Cyberkreig
way to go jesse, Explained it better than i could.. i was trying to keep them strait..
You guys do knwo there is a FAQ that answers most of these quesitions?
Justicc86
Car: anything to do with cars
I will try to give you an answer within a week when I take my s14 with a s13redtop to the track everything on it is going to be set stock
