sr20der swap over heating
cholojr19
Car: 240 sx 89-94 coupe5 speed
I just did my sr20det swap didn't hook up boost controller or boost gauge. Car is over heating by just reving it or driving a little the fan works and fuses aren't popped?
Also my rpm's in my cluster don't work I got a 1989 hatch I got a jdm cluster that came with the clip still doesn't work I even tried takin the rpm gauge out of my stock cluster still doesn't work it work before I did the swap the wiring is good wat can it be pleaseee helpppppppp?
slc240sxse
Car: 96' 240sx SE
Check your coolant levels, and you might just need to swap out the thermostat.
As far as the other problems with the cluster, I have no idea, sorry!
