uvamosk »
https://forums.nicoclub.com/uvamosk-u30063.html
Sun Mar 25, 2007 1:36 pm
Ok, So now whats wrong here. I installed radiator hoses and a new radiator into my 240sx with sr20de engine. I start the car it runs fine and everything I get all the stuff in clean up and take it for ride.
I get back turn it off and start trying to figure out why it idles is so high. (Another problem all together) anyway So I go to start it again and then it starts ups and starts jerking and jarking and shaking then just dies. I try again and this time it stays running for a little longer but just Shakes and Chugs badly then I touch the gas and it just dies right then and there. I play with it for a while and then unhook the Neg. Battery cable let it set for about 5 mins.
Guess what Now it runs and idles I say Ok cool. So i take it for a cruise and come back turn it off turn it on about 10 times No problems what so ever. Then I go to get in it about 30 mins later and it does the exact same thing again just chugs and slugs till it dies. I pull the cable again and it worked again. !!!!!
DOES ANYONE know what the hell would cause that... I have never saw it before. I know it has to be ECU or at lest I thought since I am pretty much clearing the codes in the ECU. So i checked the ECU and the ECU says 55 which means nothing wrong your screwed.
So anyone have some input. The only thing I did was I was trying to figure out what was causing the high Idle I had placed a Cap over the big line coming out of the top of the Thortal body but why would that cause this problem. I even put everything back to the way it was and its still doing this.
Thanks
