Hi guys,I browsed through the threads and don't find any that could help shed light to my problem. I am currently facing a "Cold-Start-Problem" (i think). I find it very difficult to start the car first thing in the morning and when I left the car parked for > 4 hours. The starter cranks but the engine just won't turn over. I would need to crank it 6-9 times before the engine kicks in. Flooring the gas pedal only works occasionally. Once the engine starts up, subsequent start up is a breeze (until I park it for > 4 hrs or so).
NOTE: Being in Malaysia, the "cold" temp (approx.) here refers to the region of 26-29 deg
I have replaced the following (after reading from other forums and articles) - mostly DIY:a. Car Batteryb. Distributor Capc. Temperature sensord. New NGK BKR5EY Spark plugs e.Silicone 8mm spark plug cables f. Fuel filterg. Fuel pressure regulatorh. Fuel pumpi. Starterj. fuel hosesk 3 pcs of PCV air hosesl. K&N drop in air filterm. Engine Oil - Petronas Syntium (Fully Synthetic) 15W-50n Done consult II diagnostic... appears to be fine
I got it captured:
http://jgsh77.multiply.com/vid...mptom
* Had tried choking it with at least 3 doses (bottles) of 3M fuel injector cleaners
Apart from the above, just luving it
Altima - U13 1996SR20DE
