maineimport wrote:I've seen a picture of one before... but I think it was a photoshop job. It would be a great idea if they were sequential turbos, but a typical twin turbo setup on an inline 4 cyl engine... IMHO is pretty much useless. Subaru has done it on their (oh crap the engine series has escaped me).... well one of their engines released overseas... but not on any US vehicle.
EJ20
As for the TT setup on a SR20, it'd be purely for looks. The SR20 just doesn't really have the cubes or rev's in street form to utilize fully twins. People brought up the 4 exhaust ports. Each port sends out one pulse of exhaust gas and when you collect 4 into one turbo you get an efficient spool up. When you try to use two exhaust pulses out of a piston motor you end up losing your efficiency. Instead of the turbo vanes being hit constantly by the pulses you end up with one hitting it and then a pause. This makes for more lag. It's one of the reasons the Toyota Supra with a SP63 hits full boost a few hundred RPM later than the stock setup in parallel.
People may argue that the RB26 can use two turbos but keep in mind the following:
1. 6 exhaust ports2. stock valvetrain can handle 8500 rpm 3. 0.6L more displacement
