RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Mon Feb 19, 2007 10:17 am
You will need everything from a 200sx SE-R that you don't have drivetrain wise. Obvsioulsy that means, motor, transmission, motor mounts, crossmember, axles for the LSD transmission, which would be the driver side, ECU, wiring harness, clutch, flywheel... I think you get the point.
