SR20DE throttle body on CA.....
datsunboy
Car: Datsuns
Hey guys......my mate has a SR20DE TB from a primera ( P10? ) just lying around that hes not using....and I can have it for free.
it bolts up to everything fine.....and the throttle cable lever thing should just swap on from the CA one.only problem I see is that the CA TPS wont fit?the SR TB he gave me doesnt have a TPS with it......so if I was to go buy a TPS for it.....would it work with the CA ECU?I cant see why not?
cheers for any ideas
fraz
Car: rb30det gts4
vh45 g130
I fitted a tb off an auto u12 ka24e. The ca tps fitted straight onto it.
You could use the sr tps as its just used as an idle switch on the ca
float_6969
You'd need to down load an SR FSM and look through EF&EC to make sure that the resistance is the same, and that the placement of the wires in the plug is the same.
