SR20DE/T/VE swap help into a B15
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
djoxide
Car: 07 Mazda 3 GT Sport
looking to do a swap on my 02 Sentra, of course i'd like to get the newest jdm engine which is an Avenir (98+ from the Primera) if i am correctnow other than a long list of parts needed (mounts/engine components/ecu) are there other things i should be looking out for?i'm visiting a local shop that has been doing swaps for years on imports (only one sentra-i'd try it myself but i have no place to do it all) thanks guys
i have read these threads as well which have been really helpfulhttp://www.b15sentra.net/forum...26531http://w ... 0v....html
nametakennow
Car: '06 MINI Cooper S
The Avenir is a separate model from the Primera. It's very common in Europe. I had an Avenir turbo on my Sentra for a brief period and had a lot of fun with it. VEs are very fun as well from what I've read.
Aside from parts, you are going to have to figure out how to pass emissions testing. I don't know how Canada tests, so I can't be certain that it'll be an issue. One way would be to use a JWT-tuned B14 SE-R ECU and do some wire work to make it run your B15 (you'd lose cruise control, and possibly a few other minor things), the other would be to do a stand-alone fuel management system with a stock B15 2.0 ECU. Again, this depends on how your area works.
Other than that, make sure you have the right parts, a good exhaust, and some gauges (boost and oil pressure are highly recommended, oil temp and EGT are also common) and you'll be all set. I tend to suggest that people do suspension and/or brake upgrades to be able to match their car's capabilities all around, but it depends on what you want out of it.
djoxide
i found a sr in another province in a sentra so i'm seeing if its worth buying, yes i'll def check the rules of the road for emissions as wellthanks
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
