devokc13 »
https://forums.nicoclub.com/devokc13-u83659.html
Thu Dec 13, 2007 6:37 pm
i know the rwd and the fwd heads arent the samebut i just got a rwd sr20 out of a salvage yard the block is finebut the head will need to be rebuildso i need to know if the turbo head is the same as the non turbo headto deside if i need to buy a rebuild turbo head or if i can just rebuild the head it already hasthank you very much for the info tho
[QUOTE=Hijacker]I think this is the third time in a 24 hour span I've answered this question
FWD heads are not the same as RWD heads.
RWD SR20DE should bolt up, but I do not know if it's identical.[/QUOTE
