sr20de s15 swap HELP
phase12xs13
Car: 240sx
guys i need some advice to a s15 sr20de swap,i am looking to do a sr20de swap alot of people ask me why, i like it because there are alot of stuff is interchangeable with the sr20det,first off, does any one know s13 driveshaft slips in to the s15 sr20de transmission (5speed)
how easy is the wiring compare to the s13 sr20det,which includeFuel Pump RelayTransmission Neutral SensorECU RelayAC RelayECU Backup PowerMain Ignition PowerO2 Sensor PowerECU Power
le Air Control Valve Power
the dash wiring harness heard it is more compicated,DOES ANY KNOW,please reply thannks
RPS13.5
Car: RPS13.5
I guess you have to bring your own S13 drive shaft into the shop to test fit, if it fits....
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Drive shaft should fit, but god knows if it's the right length... Probably is, if it's a 5-speed FS5W71C trans.
Wiring should be the exact same as the turbo motor, my S14 SR20DE was. Though my DE's harness and ECU was more like an S13 DE, not an S14 DET, so I don't know on the S15 for sure, but I'd imagine it would be pretty damn close if not the same.
