Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Oct 23, 2007 8:33 am
A stock FWD DE should only have a 9.5:1 ratio. My parts guy just told me that there was a eurapean variant that had 10.1:1 CR.
Flip, read my post again. You'll see that I said that I had thought the CR change was attributed to headgasket thicknesses (which is true to a degree. but not enough to account for that drastic a change in CR) A stock, FWD DE piston will have a slightly shallower dish in it, providing a slightly higher CR than a RWD DET piston. it's why everyone who buys Wiseco pistons for their RWD SRs have to contend with a higher comp piston.
ADDON: Basic physics lesson for the OP. If you compress air, it gets hotter. So in the combustion chamber, when you have fuel mixed in with the air, as the air increases in heat, it has a higher chance of igniting the gas mixed in it without the aid of a spark plug (pre-detonation). A higher octane rating is basically an estimate as to how much a gas will resist pre-detonation.
You will want to run the highest octane pump gas you can buy if you increase your CR, or run a turbo/supercharger.
