sr20de or sr20dt
mark449
I just bought a 240 with a blown motor. and i was wondering what should i do should i buy a sr20det or build a sr20de and make it a turbo. im looking for around 250-300 whp on a mustang dyno.
S13FASTBACKSR
Car: '92 Fastback SR powered
have fun modifying your car to work with a fwd engine. sr20det ftw
wildacexxx
Car: 2002 Q45 nav sport
S13FASTBACKSR wrote:have fun modifying your car to work with a fwd engine. sr20det ftw
that was a noob comment. n/a sr20de's came in rwd form also.
op.tic
welcome to nico. use the search button, this topic has been discussed many times. many people have done the conversion with success.
otterman
SR20det is easy to get those HP numbers.
SpeedRacer1
Car: 1990 240SX, G35
Stock for stock the SR20DET will have more kick and probably make those numbers better. When you take an SR20DE and add DET injectors, harness, turbo and ECU the power is more linear. It will be fast as well, but there is not nearly as much kick at WOT.
Mod the turbo, you could blow an NA block due to the higher compression.
