maxq »
https://forums.nicoclub.com/maxq-u23508.html
Mon Dec 20, 2004 5:42 am
The problem started with a timing chain rattle on startup (I had replaced the tensioner 40,000 miles ago). I replaced the tensioner again and it didn't help... Now I get bad rattle on startup, then it goes away for 5-10 minutes until the oil thins out and then a slight rattle starts. And now there is also a mechanical whine, dependent on engine rpm (I thought it was the water pump, but it doesn't leak).
At this point, I didn't believe it was a chain issue itself so I installed a oil pressure gauge to diagnose the problem. When the oil warms up, it idles okay at 10 psi... but only revs to 20 psi (@5000 rpms). However, while it's warming up (it starts at 50-55 psi after the 0 psi chain rattle for 2-3 seconds), there is the whine and a gurgle sound. You rev it up and the gurgle and whine get more intense, when you let off, the whine and gurgle stop and the pressure IMMEDIATELY drops 10 psi.
I would think the low oil pressure was worn bearings except for the gurgle that's directly related to oil pressure.... Is it possible it's something other than bearings?
Engine has 160,000 miles on it. I autox it regularly but I'm very good about changing the dino oil every 3,000 miles.
Any thoughts? TIA!
Andy
