how much you think I gonna have to spen to get the engine around 350hp? I don't need something really dammn powerfull on straight lines...I need something with good handling and a engine that won't have somes probleme because I run it in winter and I don't want to...also a good engine respons!E7-S14 wrote:I have an N/A S14 SR in my S14
Although KAs are bigger.S14 NA SRs make more to the crankand respond better to bolt ons vs the KA
although most say its not worth itthe N/A SR is a bit lighter than the KA.which is a Plus.and its a rare swap. the N/A SR.
i say go for it.better on gas too.
alright...so I guess I have to change my project and get a turbo in it ^^ thanks a lot dude!E7-S14 wrote:eh...if your looking for 350 out of the N/A...
you'd be better off with buying a Turbo SR...with an S14 SR Seeing 300 would be as easy as a turbo/ Fuel Pump/ and Injectors upgrade
The N/A SRs are weaker internally than turbo SR's..when i boost mine.im only going to be looking for around 200-250 to the wheels.thats more reasonable off the N/A
as far as 350 off of just N/A.thats a hard goal to reach off a completely Naturally aspirated motor.
when it comes to KAs and SRs .Boost is the easiest/cheapest/best way to make 300+ HP.
their are ways to make 200+ off of the N/A thobut would require alot more money than boost.
I really appreciate your help man...! really x1000 thanksE7-S14 wrote:kaela kimuraGoogle her
shes a Japanese pop star..really cute
but yeah.if your looking for 350.your best bet would be to just buy Turbo SR..if you have the money .. go for the S14 Notchtop SR
and a simple turbo upgrade and up in boost and your there
