Enigmatik33 wrote:nismo freak tryied sxoc but no one could give me a reply expect sell it and buy a sr20det, and to be honest when the next post is someone's sr20det blowing up the following someone having bought one and then being told he'll have to replace the engine, got to be honest not filling me with confidence.
I only run the car on optimax as it as. Biggest problem I have immediately is no one being able to tell me what clutch it has, contacted apex in the uk and few others and no response. Noticed primera gt and sri use variations on this engine so going to contact nissan dealer see if they can help then order clutch through work.
Also trying to find out what specific differences are. I know mine uses 4 stud instead of 5, the turbo's run 280mm discs up front, mate of a mate has 4 pot calipers i'm going to buy if i can source carriers and then run s13 4 stud front discs. Need to find out if gearbox is physically different, i.e smaller input shaft and/or ratios etc. Diff i figure will be different, i.e won't be LSD. Other question i have is whether DE head will match up to DET Bottom end, whether 24 or 20. Reason being can't be arsed with turbo lag, but I'm a big fan or super charged engines. Bro has a g40 polo. so curious whether as something a little different DET bottom end could be mated up to DE head with good port and polish mild cams headers and then supercharged for nice steady even torque curve. Figure this would make for a completely different animal to the turbo's but much nicer for road and track work. Aim would be nice 250/260 bhp
Any thoughts other than sell and buy a DET would be appreciated. Got to admit though kinda falling for the way this one drives.
The DET and DE gearboxes are the same.
The DET bottom end and DE head both bolt onto each other.
The DE bottom end will hold up to 250 - 260bhp all day just fine.
The diff is a non-LSD 4.083 ratiod unit, quicker ratio than the turbos.
The clutch is the same 225mm unit found in the turbos. FWD clutches do not fit.
The 4Pot turbo brakes are a direct bolt on if you modify the banjo fitting. Otherwise you will need lines with an IF (inverted flare)
Apex aka Bren should know what he's on about. He's a busy guy though. I've chatted with him on the phone before, real nice.
You don't need to port the head, and go with some very mild camshafts if you are supercharging the motor. Something around a Tomei 256 would be very nice and very torquey. As you limeys say, it'd be the dog's bollox mate
If you want some OEM cam upgrades, look to the early model high port FWD SR's, the intake camshafts were 248 duration with a wee bit more lift than standard S14 camshafts. It will net you a 6whp gain over standard!
