sr20de into pulsar nx
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
mykeo4
Car: nissan pulsar nx
i recently found an sr20de in my local junkyard with transmission and everything and realized that it was fwd! i have an 88 pulsar nx with the e16i series engine and i wanted to know besides the motor mounts and everything else that comes with the engine wut would i need to get that engine into my pulsar?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
There might be some fabrication involved to get the motor mounts to work.
UK-P11GT
Car: nissan primera p11 gt
you would have to get the correct mounts for the motor but the holes to secure the mounts in the bay should be the same, I take it the pulsar GTI-R is not very common in the US? then u can use the DET that mounts like a front wheel drive car but uses a transfer box to run the back wheels through a rear diff, with the Hybrid T28 aswell!
nametakennow
Car: '06 MINI Cooper S
The GTi-R doesn't exist in the US. There is no known way to use the AWD transmission either because of a different rear suspension. We import the engines and use US-market FWD transmissions.
UK-P11GT
nametakennow wrote:The GTi-R doesn't exist in the US. There is no known way to use the AWD transmission either because of a different rear suspension. We import the engines and use US-market FWD transmissions.
aaahh right! u can tell Im not from the US!!! the sunny/pulsar gti-r is probably the most insane nissan ever produced, in the uk theres lots of them. for around 6000 u.s$ for a good 1.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
