sr20de and sr20det questions
Aarow
Car: cars
what is the difference between the two?and where can you get them. can you convert a automatic to standard.
leohj
Car: Basketball, S13, S14,S15
i think the difference is..
the sr20de has no turbo in it and has less horsepower than the sr20det :cool:
well.. about the other question.. that i dont know lol :pface
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
i'll assume you are talking about s13 sr's:
SR20DE compared to the SR20DET:-no oil squirters-Distributer ignition instead of direct coild on plug-no turbo or turbo support fittings (duh)-higher compression (not turbo freindly)-less stout bottom end-Shorter transmission gears-smaller 270cc injectors-different ECU
NA SR's are still really cool though :)
NOTE: Dont even think about attempting to swap a FWD USDM SR20 into a 240, it would cost 3 times as much as just buying a JDM RWD sr20de.
Aarow
Car: cars
where can you buy a sr20det?
extheflow
there's at least 4 places directly to the left of this post
Aarow
Car: cars
how much do they cost
Aarow
Car: cars
what is the differrence between red and black tops
180fan
Car: 89 fastback
Hmm Aarow, you need to look for the button that says search up in the corner. The difference between red and black, there's a sticky at the top of the RWD SR board telling you the differences between the lot.
Onizuka
Aarow wrote:what is the differrence between red and black tops
http://www.nissaninfiniticlub....59346
Aarow
Car: cars
thanx
Turb0wned
i just bought my sr20det i payed $1000 for the engine and transmission its a redtop
Turb0wned
isnt the sr20de front wheel drive
240Knightrider
95ka24de wrote:i just bought my sr20det i payed $1000 for the engine and transmission its a redtop
WHERE WHERE WHERE?I want to know!!!
Turb0wned
240Knightrider
i bought it at some shop down here in miami that imports jap engines with 70k and under there a trusted shop i know like 5 people that have bought from them and they have all been satisfied
Def
Car: Cars, Engineering Stuffs
I can't see the $1k SR20DET coming with all the wiring and assorted accessories. Stuff like an ECU, igniter and wiring harness will EASILY make up the difference in cost and cause alot of headache in the process.
BTW - I would NOT want to do the swap without a full wiring harness after getting 75% of the way through mine. That would be a total PITA.
Hijacker
Car: '92 240sx Convertible
'94 F-150
95ka24de wrote:isnt the sr20de front wheel drive
Silvia Q's and J's. RWD DE came with a distro and higher comp pistons.
