As long as it is a FWD DET than everything will switch over. The only thing that wouldnt work would be the DE pistons in the DET as they dont have the notches for the oil squirters. The RWD DET parts should switch over as well, but why not just use the original DE as a whole? You wont make anymore power on the DET internals in the DE thatn you would with the DE, unless you had GTiR rods, as they are said to be a bit stronger than stock. But all the DEs and DETs are forged stock except for the pistons, so you wouldnt gain anything by switching the internals over unless the motor in the SER was blown. Even if it was blown, you can find FWD DEs all over for $300-$500 max, complete. I am making over 500whp on a stock JDM DE with cams, nothing else internally touched.driftsil40 wrote:I have a spare sr20det shortblock taking up space in my garage and may be getting a se-r, id like to do a turbo setup and i would like to know if the pistons and rods from the det will go into the de. Im pretty sure the pistons will not sure about the rods and crank.
Yeah, but for one point of compression difference, its not worth the hassle.driftsil40 wrote:I was not aware that the de came with forged internals. so basically the only thing it would be good for is to lower the copression. thanks
If you have a good tune, you can run just as much boost on the 9.5:1 as you can on the 8.5:1. You shouldnt have "less detonation" you should have NO detonation on any setup, because any detonation, even a little over time will kill your motor. I have been running over 500whp on a STOCK (except for cams) JDM DE (9.5:1) for about 3 years now with ZERO deontation and ZERO problems. I run an 11.9-12.0:1 AFR. I run 15-16# on pump gas, which gets me around 400whp. Most people just dont tune carefully or have something plug-n-play like JWT and dont ever do anything else, which isnt a good tune. If you have a good tune, you can run anything just about. There was somone a couple years ago that ran 10.4:1 CR built FWD SR with pump gas around 15#, with no problems.Zerogravity wrote:It all depends on your goals. Using the higher comp De block will limit how high your boost can be. The 8.5/1 will allow you to have more boost/less detonation/more timing on pump gas.
So then if I wanted to replace the internals on my FWD SR20DE then I can use aftermarket parts that are sold for RWD SR20DET like that in the Silvias?? If that's the case, then the market for stroker kits is that much better.JustinVero wrote:
