Seishuku »
https://forums.nicoclub.com/seishuku-u28745.html
Sun Nov 09, 2008 8:11 am
The valve cover doesn't have the bosses drilled and tapped for the coil packs, but other than that, you should be able to use DET coils as long as you use all DET electronics (ECU, harness, etc).
DE doesn't have:Piston oil squirtersNo sodium filled exhaust valvesTurbo pistons (IE. not low compression, with thicker ring lands)
Otherwise, it has the same connecting rods, has a crank girdle, and everything else is the same.
