SR20 versions
Acuratechva
Car: Black Kouki
i got an issue. i was sent wrong SR20DE( earlyer model like 93) but its going in 96 which has different intake manifold nad unfortunately it cant be swapped since head is slightly different. So has anybody put ealy sr20 in newer G20/sentra? please provide any input you can.tahnks
nametakennow
Car: '06 MINI Cooper S
I don't think you'll have much luck. You'd need everything from a B14 to fit that B13 motor if properly and have it with all the proper function.
You could just put it in itself, get a B13 ECU and possibly harness and say you did an OBDI conversion.
If you were sent the wrong motor, whoever sent it to you should be willing to switch it out. It's definitely too much of a hassle to swap in that '93 motor if you can just get it exchanged.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Actually he can put an older SR into a newer G20/Sentra all depending on what year he is talking about. WE put a highport JDM SR into a 1995 p10(g20). All we had to do was extend the knock sensor wire, didn't hook up any EGR either. So under that preception, you could swap a highport sr into a 200sx se-r or 98-99 sentra se or se-l. Now a roller rocker car such as the p11 or 2000-2001 se would be a no go.
nametakennow
Hmm... good call, for some reason I was thinking it'd be as difficult as an RR.
RED_DET
Vendor
2011 Infiniti G37x
There are only a few issues with the R.R. motor. Different size injectors, internal coil and ECU. But those 3 issues are too much of a headache to even try to pull off a highport/lowport swap.
Acuratechva
Car: Black Kouki
this is sort of what i was thinking. Put a resistor so that it fools ECU in to thinking that it has EGR. then swap Throttle bodys since TPS are different and everything else if not plugs in can be extended to fit. And as far as EVAP emissions i can add a vacuum gallery to make all evap stuff functional.
RED_DET, whats P10 G20... it is still obd 1 or 2 i know some split in those years. If i tell you my production year will you be albe to help me and say weather this is P10 or not?
thanks for your help guys truly apreciate it!!
EDIT: and as far as returning it i really dont want to deal with it...i only paid 400 for it and its incredibly clean no gunk at all all silver no oil leaks i mean it looks as if it has 40k...and its from japan.
i thought IF worst comes to worst ill swap head off G20 SR on to my new SR block which is main reason i am replacing it(spun main bearings)
RED_DET
Vendor
2011 Infiniti G37x
91-93 G20(P10) OBD I94-96 G20(P10) OBD II99-2002 G20(P11) OBD II/1999 G20 has non roller rocker motor.
You shouldn't have to swap throttle bodies, just the TPS.
Where did you get the motor?
Acuratechva
Car: Black Kouki
i got it from Mokoto Engines. they supply engines for our shop also but i just got lucky on this one. I can get you a site if you need it (i cant remember now)
i noticed while looking at it outside that MY G20 does not have an external coil...but engien i got does(came with dist and coil).
its not going to be an issue swaping Internal coil dist out of G20 on to my new SR is it? I dont think it will since 240 KA's are same and i can switch them back and forth all day but i jsut wanted to make sure.
SO bottom line jsut to make sure i understand this correctly. Besides swpping TPS, Dist and extending some wires to reach high port SR's manifold i wont have any problems ?
Again thanks for your input you have no idea how happy i am that i wont have to reuse that gunked up head.
RED_DET
Vendor
2011 Infiniti G37x
Just swap your old Distributor onto the new motor. You will have to extend the knock sensor wire, it runs from the injector harness to the back of the motor about dead center. Switch out TPS and don't forget to switch out the Temp Sensors. Red/Black over by the oil filter and AIC valve.
Acuratechva
Car: Black Kouki
omg i think i love you man,saved my life! my new beast will be rolling by sunday sundown muahahahah
PS: if you need any parts off my old 96 SR(all thats bad is crank/rods) let me know you just pay shipping i owe you.
RED_DET
Vendor
2011 Infiniti G37x
Glad I could help. Thanks, but no thanks on the parts, I got to many parts lying around now.
Acuratechva
Car: Black Kouki
hey man i need your help agian...hopefuly last time.basicly i am haiving an enormous brain fart. i got everything in smooth. then i put it back up in the air and about to hook up shifter linkage then as i look at it, i only see a bracket for one of the shifter "bars". here is a pic of what i am talking about
there is only one bracket there to hook up only one of the two shifter bars. WTF happened to the other!?!?!? I pulled it out after 10hour work day so i can barely remember how everything came apart but i do know there should be another bracket for the bar that pullls back and forward. I am freaking out !!! if this bracket somehow fell off i am sure it was thrown away since shop floors were cleaned night after i pulled everything out.]
i hope this makes at least some sence to you
RED_DET
Vendor
2011 Infiniti G37x
That bar should still be attached to the car. Which is attached to the shifter.
Acuratechva
Car: Black Kouki
haha i knew it was something stupid like this. it turned out i forgot to mount rear trans mount bracket which is to what one of teh bars bolts to lol.
Acuratechva
Car: Black Kouki
alright iam all done just few last questions.
what intake woudl you recomend? there is no way i can fit factory G20 intake in there. i am proably going to go with some cheap ebay stuff unless you have any good ideas.
RED_DET
Vendor
2011 Infiniti G37x
I normally run a cheap ebay filter. You can go with AEM or Injen. But they are not cheap.
nametakennow
I've always been afraid of ebay filters... I don't think K&N's are too expensive. And, as said above, there's AEM and Injen, and any other manufacturer who makes one in the right size.
Acuratechva
Car: Black Kouki
i agree, its all about the budget but i was mainly refering to the intake pipe. if you remember 96G has that damn resonator on the intake piping and with Throttle body being so much lowr in high p0rt SR its impossible to make it fit and still look clean. ill try get a pic for you later on.
mould_jesus
Car: 1996 200SX SE-R (RIP). now a 1995 240SX
auto zone for the filter.
that's probably your best bet for something cheap that doesn't carry the sketchy quality of ebay.
nametakennow
Autozone sells a cheap Ebay-ish filter and K&Ns. I still say go K&N. The filter is such an important piece that I can't imagine scrimping.
