Sr20 vacuum issue?
mjmmx6
Car: 1991 Nissan 240sx sr20det swap, 1993 mazda mx6 Fully Loaded
Not sure if this is a vacuum issue but i think it is. I just got a 1991 Nissan 240sx with the sr20det swap that has less than 500 miles on the engine. It had some idle problems which i fixed by finding a veiw vacuum problems. It now idles smooth but when i rev it up pretty high the car will come down to idle then sputter and normally die. This happens mostly when car isnt 100% warmed up. I am going to sell the car but would like to fix this problem before I do. Any ideas?mike
mjmmx6
i forgot to add in (if this even helps) that when I give it one big rev it does this, but if I rev the car up little by little it comes down and doesnt die.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
your probably running an atmospheric B.O.V.... try adjusting the spring pressure.
el OCHO
Car: 1990 rps13
are you running a atmospheric bov..that sounds mostly likely what the issue is.
redsx13
Car: 93 240sx 03 350z
mjmmx6 wrote:Not sure if this is a vacuum issue but i think it is. I just got a 1991 Nissan 240sx with the sr20det swap that has less than 500 miles on the engine. It had some idle problems which i fixed by finding a veiw vacuum problems. It now idles smooth but when i rev it up pretty high the car will come down to idle then sputter and normally die. This happens mostly when car isnt 100% warmed up. I am going to sell the car but would like to fix this problem before I do. Any ideas?mike
My car was doing the same thing!!!! i never found the problem!!! my car has been sitting for almost a year!!!!!
mjmmx6, do you have a boost gage?, is it running low boost? Does it smell like its running rich. do you have any aftermarket parts on it?
just so you guys know, its not the bov.
Someone please find the answer!!!!!!!!!!
shift_SRDETuser
Car: 1996 Nissan 240SX SE
My car was doing something similar but also include the occasional back fire...Turned out to be a build up of sludge and carbon deposits around the turbo charge pipe and hot pipe the necks that led from the turbo to the piping. Make sure they are clean as clean can be....
mjmmx6
I have a bunch of aftermarket parts on it. heres a quick list, I copied and pasted this from the site I am trying to sell it on.Sr20det, Turbo XS intercooler, Sheep Dog bov, z32 MAFS, Tial wastegate, Spec 3 racing clutch, B&B racing short shift kit, Turbo XS top mount turbo manifold, Turbonetics t3 t4 turbo, Greddy intake manifold, Griffth drag radiator, V-mount intercooler kit, 550cc injectors, Nismo fuel preasure regulator, Walbro 255 fuel pump, 17in electric fan, custom made 3in down pipe "from turbo to test pipe", 3in stanless test pipe, 3in Apexi n1 cat back, Autometer boost Gauge, Autometer air fuel Gauge, N1 white face gauges, s14 seats, 300zx brake converson with cross drilled sloted rotters, full vis body kit, molded in sides and rear, smoked tail lights, smoked corner lights.
mjmmx6
I would love to fix it so it runs the best it will but I am really big with mx6 engines and only know so much about 240's. If something on there isnt right or you need me to check something please feel free to ask and I will check asap. The vacuum lines are crazy!!Does anyone know how many vacuum lines come off the intake manifold? I really think the main part of this is a vacuum problem but when i got a diagram it isnt easy to follow cuz the previous owner ran lines all over the place
