180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Aug 17, 2004 5:52 am
Toledo, you may want to replace the large o-ring that sits between the sender unit and the fuel tank. Mine was old and stretched and leaked gas vapors into the cabin. It was like 7 or 8 bucks dealership. Also you may want to check over your fuel lines and replace them too.
If you have the smell of burning oil after running the car, keep your motor running a minute or two after you give it a run and let the oil cool down your turbo and let the oil cool down. Possibly invest in a oil cooler. Do you have any puddles of oil on your turbo or worse yet, in that would make the smell a bit more obvious?
tune up with the sr, change the plugs for sure. I didn't like the idea of using the plugs my motor came with so I changed them to NGK Iridium IX's. Check the timing also. This should have been done at the time of the install or after any valvetrain work is done. That could be the answer to your sluggishness.
