hey guys i was just doing some checkup on my sr20. found out my signal wire is so off
im getting
5v - Reference Volt
4.70 - Signal Volt with it closed. 1.03 - Signal Volt with it WOT.
Without the TPS female end attached. I measure the Signal Wire, reads 2V
I tried adjusting the TPS. it only goes up to 5.08 MAX and down 4.70 LOWEST, cannot go back down to .45v
So what is going on? Bad tps?
thanks
