GTS4-R »
https://forums.nicoclub.com/gts4-r-u1728.html
Fri Aug 31, 2007 4:52 am
I've got this car running at 442 rwhp
NO CHEAP OR EBAY PRODUCTS ON THIS CAR!!! everything is top of the line
Engine: *1993 JDM Redtop S13 SR20DET ($2,500)*Greddy Spec R Front Mount Intercooler and piping ($1000)*T3/T04E Precision Turbo (sc-61) .60 a/r comp. .63 ar exhuast stage 5 wheel ($900)*Full-Race T3 topmount manifold ($1,200)*Tial 40MM External Wastegate ($300)*HKS 264 Camshafts (in/ex). ($550)*Splitfire Aftermarket Coil on Plug Ignition w/ coils ($500)*Turbo Extension to Downpipe ($150)*Tomei Valve Springs ($225)*Tomei Rocker Arm Stoppers ($125)*Tomei 1.2mm Head Gasket ($200)*Greddy Intake Manifold ($500)*Ported and Portmatched Head ($200)*Tomei 740cc Injectors ($550)*Secret Services Custom Tuned ECU ($550)*Koyo Aluminum radiator ($300)*Nismo Motor Mounts ($250)*Nismo transmission Mount (^^^)*Blitz Cooling Performer radiator hose ($125)*Samco lower rad hose ($70)*300ZX Z32 Mass Air Flow Sensor ($175)*Apexi Intake for Z32 MAFS conversion ($150)*ARP Main Head Stud Kit ($125)*Greddy gauges (Air/Fuel Ratio, Exhaust Gas Temperature, and Oil Pressure) ($700 for all 3)*Blitz BL series gauges in dual pillar pod (Boost, Engine Temp) ($400 for both)*Kaaz 2-way Limited Slip Differental ($900)*Greddy Baffled Oil Pan ($225)*HKS Super Sequential Blow Off Valve ($225)*Custom (Heavy Throttle) Stainless 3" Downpipe ($150)*Stainless (Heavy Throttle) 3" test pipe ($90)*Apexi 3.74in GT Spec Exhaust ($600)*Stinger SP-800 Drycell Battery ($200)*PermaCool Dual Electric Fans ($225)*Walboro High Flow Fuel Pump ($125)*ACT Street/Strip Clutch with Xtreme Pressure plate ($500)*Greddy Turbo Timer ($100)*Greddy E-01 Boost Controller ($500)*GReddy E-Manage Fuel Management run off Gateway Laptop and GReddy E-01 (Sold- wouldn't run on my redtop for some reason) *Apexi S-AFC2 ($250)
$16335 into engine.....much more into rest of car
All PLUS SHIPPING...LABOR and PATIENCE/TIME
thats all i can think of right now....i know there is more
Modified by 93Niss240 at 12:17 PM 8/31/2007
Modified by 93Niss240 at 12:21 PM 8/31/2007
