Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Jun 15, 2009 2:37 am
Then the issue is in your timing. You can check timing while it's being cranked.
If you have an inductive pick up light, hook the battery leads up to their proper terminals on the battery. On SRs, there is usually a black loop of wire that sticks out of the coil pack harness in the back. This is an inductive loop that you hook the wire clamp to. If you can't find it, or you have difficulty with making it work, I suggest taking a piece of spark plug wire, and putting it up coil pack and then seating the boot on your plug. It should look like this:
I would recommend using a little tape to hold it, but once you're done, you can take it all off and continue normal use of the coil pack.
And I apologize for forgetting that there was no ignitor on an S15. Just wasn't thinking.
