kornmanz wrote:Yeah there is a small gap in my turbo to downpipe. I used to have a problem with my turbo to manifold but I fixed that real good and put pics in my build thread. I will check the start signals. After checking the fuse box where will I find the signal wiring?
Fuse panel by the drivers door its a 10 amp fuse. I will need to check online to find the pin and wire color, I dont have the info available this second, but I believe it is the orange wire on your ecu that is conneted at the dash connector on the passenger side (not 100% on this, as its been a while) this might be the reason your having trouble starting it. Is the vehicle starting fine after it warms up? If it is I would bet your start issue is in that wiring, if not I would eliminate it as an issue. You might want to test your alternator too, car might be running poorly due to a weak alt after it finally starts.
