Actually it's in the 510 so I don't have a tach....tach installed properly. Everything works fine, got power but just don't work in this tach,I'm pretty sure the tach is working. I heard if I'll use bliz,or any japanese tach will work with no problem. I might going to change it then if i can't make this one work. Thanks anyway..PyR0NiAk wrote:The stock one not big enough??![]()
Either way, it looks like you're using the right wire... Are you getting power, or just no signal?
