sr20 tach 12v
2jz.s13
So with the 89 240sx the tach wont wire with the coils. Will an aftermarket tach work or do i need to wire it directly to the ECU, or will i need a specific 12v aftermarket tach, or will I only be able to get it work correctly with an adapter?
2jz.s13
To the top.... Help please, I can't find a straight answer anywhere.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
FR Sport has a good write up on modifying your harness.Check them out.
2jz.s13
As in the website? I need a little more info then this but thanks for trying. Like a link, or something. I tried to find what you were taking about with no luck...
Doesn't anyone know if I can just use a aftermarket tach straight to the ECU or to the coils? Or anything? I mean hasn't someone used an aftermarket tach and not the 92-94 gauge cluster before??? Does anyone understand the basic layout of aftermarket tachs to know if I will have to get a special 12v one or are all compatible with 12v?
HELP!
sx moneypit
1986 Toyota MR2
Go to marketplace,scroll down to FR Sport and click on,then scroll all the way down to the bottom of the page and you will see technical articles.
2jz.s13
Thanks man I appreciate it
sx moneypit wrote:Go to marketplace,scroll down to FR Sport and click on,then scroll all the way down to the bottom of the page and you will see technical articles.
I will keep the thread updated if it helps, and I will post an answer if I find one.
sx moneypit
1986 Toyota MR2
No problem brother! I need to learn how post links and pictures just haven't had the time.
2jz.s13
haha I feel you. No need to waste time with pics, links are great.
This helps a little with the wiring cluster pictures, but no info on the tachometer set up at all :S. It mentioned what wire is the tach wire but nothing about the problem all SOHC 240sx swappers run into with the tach.
Unless anyone has any objections, I think I am just going to buy an aftermarket tach and try to wire it to the normal red/yellow tach wires, and if that doesn't work try to wire it directly to the ECU. If none of that works I will buy an adapter.
If anyone can help, please do! I don't want to waste money on an aftermarket tach if I don't have to.
sx moneypit
1986 Toyota MR2
If you are running an SR20 why not just get a DOHC cluster or just swap the tach out?
2jz.s13
I am cheap.
sx moneypit wrote:If you are running an SR20 why not just get a DOHC cluster or just swap the tach out?
sx moneypit
1986 Toyota MR2
In the 240sx tech articles they have a write up on how to convert the KA tach to read the KADE tach signal.The pictures are gone but the write up is still there.
J14cm7
Car: 95 240sx S14 SR20det
Arent you guys just over thinking this? Cant you just find the ecu tach output and wire your tach to that?
2jz.s13
I think so.. I mean it is just a normal tach signal right? It's not a dumb variable voltage one like the KA24E is.......... I have no idea. It's over though, don't worry about it. Car is gone. Thanks for the help though.
sx moneypit
1986 Toyota MR2
No problem brother!
