SR20 T28 on RB25
FinkenS14
Car: 1995 Nissan 240sx S14
Hey guys I got the idea of putting an SR20 T28 on my RB, since the stock turbo is a POS and cant go above 12psi without blowing up.
So I was thinking, my friends still making power on 17psi on his SR20 T28, and hes gt a spare, think id gain anything going from an RB turbo at 12psi to an SR T28 at 17psi?
Thanks!
GSDKinked
Car: 1997 240SX LE
And you just took a left onto fail street....
rb25det250sx
Car: '96 Nissan 240SX RB25DET powered!!!
not 100% sure, but im perty sure that the sr20 turbos are t25.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
late s14 and all s15 turbos are t28's
still to small of a exhaust wheel,
ive been running 16psi on my stock turbo for months now, i know they go bad but ive yet to have a mess up with mine
Cjmartz2k
Car: Hunting for a '89 GTR now
Bottom line, they have different exhaust flanges and will not bolt up to each other.
robbie2883
Car: 1998 RB25 Kouki
SullivanRacing06 wrote:late s14 and all s15 turbos are t28's
yeah...i was gonna say, i've been running 1 bar for over a year without issues and when i was in europe 80% of the skylines there with stock turbos were running 17 psi for long periods without issues. i'm a true believer that tune has everything to do with how well the stock turbo's hold up
SullivanRacing06
egts determine how long the turbo will last!
FinkenS14
I know the exhaust flanges arent the same, and I know some turbo lines might need to be modified aswell as intercooler piping and exhaust. This isnt my first ball game guys.
FinkenS14
16psi on a stock RB25 turbo? Damn....
I wodner if Id be able to get away with doing that with the higher altitude in Colorado, and my 4" exhaust.
julio
Car: RB26 AWD converted S14
FinkenS14 wrote:I know the exhaust flanges arent the same, and I know some turbo lines might need to be modified aswell as intercooler piping and exhaust. This isnt my first ball game guys.
It may not be your first rodeo, but you're asking for it when you suggest putting a t2 flanged turbo on a 2.5l engine. How do you plan on mounting it to your manifold anyways, I'm not sure if they make an adapter for those sizes?
robbie2883
julio wrote: How do you plan on mounting it to your manifold anyways, I'm not sure if they make an adapter for those sizes?
Image??????????????????????????????????????????????
julio
And I thought RTV was the gear heads' version duct tape (aka handyman's secret weapon).
RustspecS13
Car: '74 260z and '88 300zx turbo
The question is will the rb25 exhaust housing bolt onto the sr20 exhaust side of the center cartridge. Or will an rb20 rear housing work on the sr20 center cartridge.
Your better off getting a T3 from a l28et or a VG30ET if you want a nissan turbo.
~Alex
robbie2883
nope...that's actually multi colored zip ties
FinkenS14
I thought SR turbos were T3?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Negative. it is a T25 or 8.
*Edit* apparently HTML codes do not work with BBCode..
FinkenS14
OK, so whats the name of an RB25 turbo? I always thought it was a T28 of the sort.
GSDKinked
Car: 1997 240SX LE
FinkenS14 wrote:OK, so whats the name of an RB25 turbo? I always thought it was a T28 of the sort.
It is a DIFFERENT T28 with a T3 flange
RustspecS13
I know the RB20 turbo is a t3 flanged T25/8 but I thought the RB25 was a straight t3- since the Z31/L28 share pretty much the same turbo.
~Alex
R32ONP
Car: R32 Skyline GTS-T
RB20DET
well hu da F=+* said it a t28 with a t3 flange?????? its not lol t25s and t28s are made by garret...rb turbos are not they are made by nissan...its a rip off of a garret t3 and nissan used a ceramic shaft instead of garrets inconel shaft...big mistake thats y they snap...as far as im aware the rb25 and rb20 use the same s*** small exhaust wheel and small housing and the difference is that the rb20det has a small intake housing and a small alloy wheel and the rb25 has a much larger intake housing and a composite plastic wheel which doesnt like alota boost either......
R32ONP
RB20DET
but there is a much better varient of the rb25 turbo.its from a vg30det 300zx..its the same housings as a rb25det turbo but instead of composite plastic wheel it has the alloy wheel....
Cjmartz2k
R32ONP wrote:but there is a much better varient of the rb25 turbo.its from a vg30det 300zx..its the same housings as a rb25det turbo but instead of composite plastic wheel it has the alloy wheel....
No, it's got a different exhaust housing (which is way to big compared to the compressor side). That turbo sucks in stock form. To much lag for not enough power.
Cjmartz2k
***O yeah, and the RB2 turbo IS a T28 with a T3 flange.
robbie2883
too much google in this thread! LMAO
