SR20 T25 clocking, just a quick confirmation!
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
The center piece (where the oil and coolant lines go into) is supposed to rotate. Well, after loosing the 4 bolts on the exuast side... it wont rotate seperatly from the center piece, nor does it want to come apart. Am i missing another piece to hold them in? Or maybe they are just kinda siezed together.
anyone else get this problem?
superJoy
Car: 1989 RS13
You need to rotate the compressor housing (the silver part). You shouldn't need to mess with the exhaust side. It's held in with a large snap ring. You need to compress the ring with a very large pair of snap ring pliers and just turn the housing. How long it takes is directly relative to how beefy your snap ring pliers are. I used some of these:
Hitec #65. They cost about $35 but they made it a snap. (No pun intended, hehe.)
Liquid_Neon
rotateing the compresser isnt hard. but the oil and coolant lines are not lined up. I must rotate the unit so the lines will fit. as it is, mounted to my manifold.. none of the lines will fit.
Snap rings arnt a problem, i already moved that
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
Liquid_Neon wrote:rotateing the compresser isnt hard. but the oil and coolant lines are not lined up. I must rotate the unit so the lines will fit. as it is, mounted to my manifold.. none of the lines will fit.
When I clocked mine, I loosened the 4 bolts on the turbine housing and rotated it with ease. Loosen the bolts, not remove them. Worked like a charm for me with no problems.
Wei
davidricardo86
Car: 1992 Nissan 240SX SE
Wei
This will work if your exhaust housing and CHRA arent seized. For example, when i took apart my ca t25 i got to the four bolts and i couldnt move it at all. It rusted up and i had to use wd40 and eventually a torch to seperate the two. They were stuck pretty good but i kept heating it and tapping it out with a rubber mallet. Eventually it came out but you could see where it was rusted together. I put the turbo back together and this time around i put a little bit of anit-seize on the part where the two meet, just enough to preven this from happening again.
Logan76
Car: Junk
I just took it off my manifold and took my lines off, then got the snap ring off, and turned that biatch.
Liquid_Neon
took it to work today, used a torch and a hammer. had it in a vyce and tried turning the exuast houseing apart from the center... no good still couldnt budge!
dam thing is siezed up something fierce.
Guess since i cant get it to move im gonna have to get new lines for my oil since the old ones arnt long enuf and are at wrong angles.
