15s should be no sweat. The car is so light that with the SE-R's SR power 15s aren't far away. I want to say, and I'm sure someone can give you better info, that I/H/E, suspension, good tires, and cams will do it.
http://sr20forum.com/showthrea...+time
The fact is that you don't need S5s to run that time. The power curve on those is so far up top that he wasted enough time down low and in the middle to even out his 1/4 in the end, I believe.
I fully intend to run good 14s with I/H/E, cams, pulleys, high-flow cat, flywheel and street rubber on the heftier B15 (I won't be stripping anything, maybe take out the rear seat if I'm in a bad need of an extra .01sec, lol), and I'd venture to say I'm not far off.
