sr20 swap?
nissanmini97
Car: 97 nissan hardbody ext. cab
i have a 97 hardbody and im wondering what is involved in do an sr20det swap into my truck any help would be greatly appreciated
Altiman94
Car: 1989 Nissan 240SX
same things as the sr swap in the 240sx more or less
s13sr20chris
few differences i would imagine. i think if you are interested it should not be too hard. i think the steering/manifold will be a little more of an issue.
nissanmini97
im sorta new to nissans so can anyone explain in little more detail...
s13sr20chris
ok, you pull out the old motor. then you have to figure a way to get the new motor to sit in the truck. this is easy on 240s as they use the same mounts. they prob do in the trucks too. then you may need to work some magic on the steering shaft or get a custom exhaust manifold to clear it. then you run the wiring harness to all the plugs and stuff the ecm in the truck somewhere. then you have to match up a few wires in the engine harness with the trucks main harness. i dont remember which ones. this should be similar to one of the write ups into a 240. the differences will all be on the truck side. then hook up your custom exhaust, intake, and intercooler setup. the driveshaft may fit or it may not. i dunno. if you have a cutter and welder you can make it fit.
